Old 08-15-2010, 09:03 PM
grumpy's Avatar
grumpy grumpy is offline
Administrator Bowtie Member
Default To rebuild or buy new
I figured our TH350 would live behind the new motor, but it seems I'm wrong. Everything I have read about TH350's says they can survive up to HP but it can get really expensive.
Question is it worth rebuilding or going to another trans such as the TH400 or ? Thanks for your input.
Dave
Dave
Old 08-15-2010, 09:13 PM
Rattler's Avatar
Rattler Rattler is offline
Is this car going to be racing at the track with slicks? or just smoking tires around the neighborhood? Is the trans stock now?
Old 08-15-2010, 09:28 PM
grumpy's Avatar
The trans is stock with a shift kit. Its going to be on the street and strip, would not mind it performing decent on the autocross track.
Dave
Old 08-15-2010, 09:35 PM
grumpy's Avatar
I would but the budget is a big concern right now.
Dave
Old 08-15-2010, 09:41 PM
Chevelle_Nut's Avatar
Chevelle_Nut Chevelle_Nut is offline
THM350's are tough but I am not pushing horsepower because mine is stock. Let me say that in 254,000 miles and 38 years the transmission has never been rebuilt.
Jon Hart http://www.coolharts.com
72 Chevelle Malibu / 69 Chevelle Malibu 4 Door
72 Chevelle Malibu Father/Son Project-- In Pieces
Rattler's Avatar
If you plan on hitting the strip then go with the turbo 400. You would have too much money into the t350 to make it as strong as a mildly built t400. 400's can be picked up pretty cheap and rebuilds aren't too expensive.
Old 08-15-2010, 09:49 PM
grumpy's Avatar
A 400 would be cool cause then I could have our current converter rebuilt and use it.
Dave
Old 08-15-2010, 09:52 PM
You'll lose more power spinning a TH400 than you will a TH350. You can definitely find a TH350 that will take the power you guys are making. If you can find a worthy shop, a rebuild and "beef up" are probably the best option.
If I ever have the $ for a transmission, I'm getting an overdrive. Either a 700R4 or a 2004R. Those both have lock-up features, and real nice first gears. The 700R4 requires a shortened driveshaft, but the 2004R doesn't, from what I've read, you only need to move the crossmember a few inches. Either one of them will set you back well over a grand with a converter though.
Rattler's Avatar
I've got a Hughes 6k stall for sale. LOL! not exactly streetable.
Old 08-15-2010, 09:55 PM
grumpy's Avatar
Right now I can only budget about 12 maybe 1300.00 for the trans.
Dave
