Old 11-19-2010, 06:29 PM
Chevelle_Nut's Avatar
Chevelle_Nut Chevelle_Nut is offline
Default A/C Compressor Wiring
My 69's compressor won't engage all of the time. If I give the clutch a 12 volt direct connect it will come on but from the dash it will not. I replaced the plunger switch, after replacement it engaged a couple of times but quit again. The green wire runs to the compressor from the switch, is there a junction or relay between the switch and compressor? The wiring diagrams online do not include the A/C circuit. Does anyone have any wiring diagram for a 69 they can post or link to? Thanks in advance
Jon Hart http://www.coolharts.com
72 Chevelle Malibu / 69 Chevelle Malibu 4 Door
72 Chevelle Malibu Father/Son Project-- In Pieces
Old 11-19-2010, 07:44 PM
No AC on my car so I can't say for sure. Not sure when they started using them but AC systems typically have a pressure switch somewhere. If there is no charge in the system, all the freon has leaked out, the pressure switch opens and the compressor won't go on. Keeps the compressor from burning up from running dry. Check the AC plumbing, receiver/dryer, etc to see if there is a switch in it somewhere. Could be a bad switch or low freon level.
Old 11-20-2010, 05:26 AM
The freon is full, if I jump the compressor over using a 12 volt wire from the batt to the terminal on the compressor it will freeze your tail off. The 69 does not have a superheat switch like a 72 does.
Old 11-20-2010, 06:25 AM
Isn't there a relay on the firewall somewhere? I'm trying to remember, I've seen some of the wiring for the AC circuit but don't recall the details.
Old 11-20-2010, 08:43 AM
I just came back in, the ambient sensor on the evaporator housing is in line between the control head and compressor, I ohm ed it it and the wire is good from the compressor to the ambient. I jumped the ambient and still no luck. I am going to do more wire tracing a little later.
Old 11-20-2010, 02:24 PM
Here is what I found, on a 69 everything feeds back to the blower switch, it acts a power distribution junction. I am gong to try to repair the switch first before replacing it.
