Old 11-26-2010, 10:54 AM
69SS396's Avatar
69SS396 69SS396 is offline
Default Drive Shaft Hitting
I have stock heavy duty coils in the rear of my 69 and when riding around with two people in the car, the balance weights on the front of the drive shaft will hit the box floor reinforcement just behind the tailshaft of the Muncie. Not sure how to resolve this. Rear tranny mount is a stock, new replacement as are the rear coils. Ride height of rear is slightly low but seems similar to other stock 69's I have seen. Maybe I have the balancing weights moved rearward and the shaft rebalanced? Would be a good opportunity to replace U-joints and rear yoke? Car has had floor pan replaced, could they have done something wrong??
Ed
On the 7th Day God Created Rat Motors!
Member - Peach State Chevelle Club
http://s1095.photobucket.com/albums/i475/nfa1eab/
Old 11-28-2010, 09:33 PM
Do you have the correct tranny mount? There are two, one is taller then the other. If I remember correctly the taller one is for an automatic and the shorter on is for a 4 speed.
Old 11-29-2010, 11:46 PM
69SS396's Avatar
Do you have the correct tranny mount? There are two, one is taller then the other. If I remember correctly the taller on is for an automatic and the shorter on is for a 4 speed.
Ray,
Mount was purchased new from ground up for a 4 speed when I rebuilt the muncie. Do you know what the dimension is for an auto mount or a 4 speed mount? i will measure mine tomorrow, but there is not much clearance at the top of the fan shroud for the engine to tip down in back and up at the front??
Ed
Old 12-01-2010, 07:56 AM
Ed, I have a new automatic mount on my work bench at home, I can measure for you. I'm out of town until friday.
Old 12-01-2010, 07:58 AM
Are your body mounts good?
Old 12-01-2010, 09:01 PM
69SS396's Avatar
Derek,
I think so. Body was off frame about 8 years ago and they were new then. Can they go that fast?
Ed
