Old 04-30-2011, 10:13 AM
Bowtie-Bri's Avatar
Default Differential cover leaking......Arh
I used a gasket and the permatex "Ultra Gray" gasket sealant. Yesterday when I was under my car, I noticed a drip hanging from the bottom of the diff. I retorqued the bolts, but its still leaking. So now I'm about to remove the cover, clean everything up and try again. Since the car hasn't been drivin yet, I'm planning to reuse the gear oil.
Wish me luck....
Brian
Old 04-30-2011, 05:09 PM
Brian, I hope that everything works out. Good Luck !
Old 04-30-2011, 05:26 PM
That's what you get for messing with shit that ain't broke. J/K, I'm sure you'll get it sealed up
Old 04-30-2011, 07:43 PM
itamike itamike is offline
Wish me luck....
Good luck Brian,i'm sure you will win,just curious,is in a girdle type aluminum cover or stock diff cover?
Old 04-30-2011, 09:26 PM
Bowtie-Bri's Avatar
Just trying to make it alittle better Hank.
You know how it goes, tamper with something that holds oil, and you risk the chance of leaks. Hopefully it won't leak this time.
Thanks Mike,
Its a stock diff. cover. check out the pics in the thread about my rearend (Differential) that is. Those are pics I posted last week before I put it back into the car.
Brian
Old 05-01-2011, 07:43 PM
Good luck with the drip.
Old 05-06-2011, 10:13 PM
Bowtie-Bri's Avatar
Today I refilled the diff. Hopefully its sealed and won't leak. Might be taking it out for a test drive this weekend.
Brian
