Old 07-25-2011, 08:47 PM
Default Chevelle AC/heater install
ok i think i worded this wrong so let me redo it. i went to install the AC box and i went to test fit it and i noticed that the part where the fan goes was missing and it looks like this
now what i need my fire wall to look like is this correct?
if so where can i get that part in the second picture so i can install AC and heat in my car?
Old 07-26-2011, 12:10 AM
Top picture is a non AC car and the lower is for a AC car. Hope that helps. They do make a heater box that goes over the AC unit area if you don't want AC. http://www.acdelete.com/pages/68-72_A-Body.htm
Old 07-26-2011, 08:35 AM
ok i edited my first post i think i was flustered or something when i did the first post. see if it makes a little more sense now
Old 07-26-2011, 11:56 PM
It looks like someone cut a section out of your firewall. Do you have any idea what happenen to it? The one piece you are missing had your hidden vin on it. If you don't have the piece that is missing you are going to need a parts car to get that section.
Old 07-27-2011, 01:51 PM
Berg's Avatar
Berg Berg is offline
Shaun- Check this out from Ground Up. It is the Passenger side cowl shoulder with the blower motor cutout and flange. I believe this is what you need. If the firewall is cut (most drag cars are welded but yours appears to have been patched if this is the yellow car) they make a firewall panel too.
http://www.ss396.com/mm5/merchant.mv...t_Code=RCS-68R
http://www.ss396.com/mm5/merchant.mv...Code=RFP-1461A
84 K5 Blazer 350/SM465
75 K5 Blazer 355/SM465/8 lugs
Old 07-27-2011, 02:10 PM
dude you hit it right on the HEAD!! thats exactly what i need in the first picture!!! thank you so much!
