Old 09-02-2011, 10:40 PM
crengo's Avatar
crengo crengo is offline
Default brakes coming on without touching pedal
i have a 72 chevelle with the ssbc front disc brake conversion kit installed with 18'' wheels, after driving for 15 to 20 min the front brakes start to come on with out touching the pedal,im at my wits end. any advice would really help
Old 09-03-2011, 08:59 AM
I would suspect contamination in your lines some where. What brake is coming on?
Old 09-03-2011, 10:25 AM
Are they coming on without touching the pedal at all, or just not releasing after they've been used?
If they're coming on without touching the pedal at all, I'd suspect a bad vacuum booster.
If they're not releasing after they've been used, I'd suspect a bad brake hose that's swollen shut.
Old 09-04-2011, 10:37 AM
crengo's Avatar
thanks for the greating info, its the front brakes that are staying on
Old 10-25-2011, 06:59 AM
hmrmcpy hmrmcpy is offline
Sorry, just a replay to say, and check the posting process.
Old 10-28-2011, 01:22 AM
Ki_Power's Avatar
Ki_Power Ki_Power is offline
same problem I have... I have SSBC disc on all four. After 20-30 minutes....same deal!
What's up?
Old 10-28-2011, 08:34 AM
Make sure the rod from the brake pedal to the master cylinder is in the right hole and not binding up against the firewall.
Old 10-29-2011, 02:12 PM
Ki_Power's Avatar
The right hole and not the left?
For real, which hole and how many would there be?
