Old 09-15-2011, 09:46 AM
Default bench or bucket?
ok guys and gals my chevelle came with bucket seats i have the bucket seats but not sure if i want to even use them. they are in BAD shape and everything needs to be replaced. a buddy of mine has a bench seat just dirty and its out of a 68 i was thinking about getting them but i am not sure what i should do. so i ask what would you guys do get the bench seat or take the time and money to restore the front buckets?
Old 09-15-2011, 10:32 AM
I think that it is personal preference. When I got mine it had the bench seat that was totally trashed, plus we had a set of bucket seats. I went with the buckets, but in some ways I wish that I had kept the bench.
I think it comes down to what are you looking for in seating? I think that the buckets make it a sportier look, and maybe more stability in the seat. The bench gives you more room for passengers, and more chance of getting that special someone right beside you in the seat as you go out for a cruise. In 69 you still had only the lap belt, so I would think about that, especially if you are planning on putting any power under the hood. Are you going with a more original look? There are so many things to consider, and only you can answer those questions. I will tell you that from my experience, spend the money now, because ultimately if you are not happy with the cheaper route, you will spend the money anyway. Just my 2 cents.
Old 09-15-2011, 11:00 PM
If the frames are solid they can be used. I took mine apart had them sand blasted and expoyed primered them and painted them . If your springs are ok you can used them and just buy new foam and covers. I replaced mine because of broken springs. It wasn't that bad to redo them. I think the springs are $70 each and the foam run about $130 for both seats. Buckets is the only way to go for me. You can put the covers on yourself also.
Old 10-05-2011, 10:56 AM
70SS396 70SS396 is offline
I like my bench seat. It seems to me that bench seats are rarer because a lot of owners ditch the bench for buckets. I get a lot of positive comments about it having a bench seat.
Mike
Old 10-05-2011, 12:17 PM
Yea i was just being lazy and not wanting to do both seats! but i am going to stick to it only because i have the center console but my wife likes the idea of having the bench for more room but then she was thinking it might be a little harder to look back when my daughter is sitting in the back seat. so i am not sure yet. i am going to finish the rear seat in the next month and then we shall see
Old 10-05-2011, 03:44 PM
The floor mounts for a bench seat are not the same as for buckets so it's not a direct swap. You would have to weld in new mounts.
I did my buckets, foam was good, had to replace some springs and new covers. I wouldn't call it a simple job putting on the new covers but you can do it.
Old 10-06-2011, 06:58 AM
my seats need new foam and covers as far as i can see on the bottom no new springs needed so far
Old 10-06-2011, 05:13 PM
I have 1 with bench and 1 with buckets and I like the buckets best.
Old 10-06-2011, 06:57 PM
Holy crap,Ray.Them seat frames are awesome. I you go with the bench,then your lady can sit real close to you.Sometimes I wish I had the bench,Avis is so far away.
Old 10-18-2012, 11:14 AM
jaybodine59 jaybodine59 is offline
I'll trade me bench for buckets anyday!!
72 Chevelle Malibu Convertible
72 Impala Custom
