Old 09-15-2011, 06:01 PM
71-SS350 71-SS350 is offline
Default Wiper Arm Spring
Since the wiper arm spring on the driver side took it's leave from the arm sometime ago (??) just want to know, is it possible to change the spring or replace it? Hope to remove a spring from a spare passenger arm and use it for a replacement. For the passenger side I would just change the arm as I have a couple spares. Naturally it has to be the drivers side of which I have no spare. Also what's the best way to remove the arm without damaging the paint or windshield?
Old 09-26-2011, 03:58 AM
Well, I finally found a replacement driver's side arm and fixed that problem. Used a wide flat blade screwdriver and carefully pried up from side to side and arm popped right off. Don't think I will be able to repair the replaced arm, the arm is damaged where the spring attach rod inserts to the arm to hold tension for the spring. Guess that explains why the spring decided to take leave of the situation. Now need to look for another spare to have on hand. Always like to have spare parts for 40 year old vehicles. Guess that is why my garage, shop and parts shed is so full.
