Old 11-14-2011, 12:20 PM
mprat mprat is offline
Default 12 bollt posi axial removal
I pulled my rear end out of my 67 chevelle need to remove the axials, first thing I found it its a posi out of a 70 to 72 chevelle, and I know how to get as far as removing the c clips etc. I am not familar with this one which has a spring pack in the center with four springs and I do not know how to remove it. I read a bunch of how to on the net but could not find one that showed these springs. this spring assy has to come out befor I can get the c clips out. before I do something I will regret, do you just pry the springs out one at a time or????
Old 11-25-2011, 02:47 PM
72ss383's Avatar
72ss383 72ss383 is offline
i took the cross shaft pin out ,push axle in take out the c clip..then pull out axle ..no prying on the springs
