Old 11-16-2011, 09:50 AM
Default trunk harness
hey guys can someone do me a favor and show me how the harness from the trunk to the inside of the cab should be ran please? i want to make sure i am running this in the right spot.
here is what my rear looks like now where the seat goes
is this correct? should that metal plate be there?
and not pictured but right above the wheel well is a small square and that is where i have the harness running from the trunk. is that the correct spot?
Old 11-16-2011, 03:10 PM
There should be a cardboard divider instead of what you have there, looks to be metal. It hangs on the metal divider where the seat back hooks. You can the see the cardboard through the holes in the metal. If you want one you can get the divider from just about any of the suppliers.
In the post linked below you can see where the wiring comes into the trunk.
http://chevelleforum.org/showthread....ighlight=trunk
Old 11-16-2011, 05:01 PM
thanks a lot man! but my trunk looks nothing like that i will snap some pics and show you
Old 11-16-2011, 05:52 PM
Sorry, forgot you have a 69, not a 70. Maybe someone else with a 69 can shoot some pics for you.
Old 11-16-2011, 07:43 PM
68 to 72 use the same trunk divider, your does not look correct. The wiring harness should run along the bottom of the floor pan and have clips that hold it in place as it comes up the floor pan to the trunk.
http://www.ss396.com/mm5/merchant.mv...uct_Code=ITD-9
Old 11-16-2011, 10:01 PM
here is what my trunk looks like
let me know what you think
Old 11-17-2011, 06:31 AM
Looks like someone replaced or covered the metal divider. It's definitely not solid, should like similar to mine. Also on the inside, the screws or rivets aren't a factory thing.
Old 11-17-2011, 07:34 AM
so this leads me to my next question. might be a new topic but i need to know can i put my back seats in with this kind of back?
Old 11-17-2011, 07:54 AM
This is what the inside of my trunk looks like looking forward. Just not sure how strong it is if they cut out the original metal from the pictures. Otherwise the only time you will know something is different is only when the trunk is open, you will never know from inside the car.
Old 11-17-2011, 08:28 AM
do any of those holes have anything to do with putting the rear seat in?
