Old 03-20-2012, 10:17 AM
93svtlightning 93svtlightning is offline
Default frame ?
I'm in need of a frame for my 69 convertible. What are my options? Does anyone have any leads to where I can find one thanks
1969 chevelle ss convertible (project), 1965 Chevrolet C10, 1993 ford lightning, 1991 Mustang Coupe Coyote Swap, 2014 f250 6.7 Powerstroke
Old 03-23-2012, 06:22 PM
You can get these frames from any "A" body(cutlass,skylark,,etc.) Convertable frames follow the same suit. 68 to 72 have suttle diffences if you had one of those years.
Old 03-23-2012, 09:04 PM
So I can't use a 68 or 70-72 frame. Well that just made the search harder great!
Old 03-23-2012, 10:39 PM
I just did some more checking and a 68-72 frame are the same dimensions. There are slight differences in the frames but it looks like they will work from what I have been told. I just had a friend put a 70 frame under his 2 door 69 coupe. A 1968 frame has an extra metal V shaped guard under the front crossmember.
Frame info http://chevellestuff.net/qd/frames.htm
http://s193.photobucket.com/albums/z...=framedims.jpg
Old 01-03-2013, 01:18 PM
I have found a frame that has been converted to a convertible frame. Should I stay away or will it be OK?
Old 01-03-2013, 01:46 PM
Look it over good, make sure it is still nice and square. Check out the integrity of the welds.
If you want a nice hard top frame to convert yourself, I have just recently acquired one as of today.
Old 01-03-2013, 03:04 PM
Well the problem with that is the frame is on ebay
