Old 06-17-2012, 04:04 PM
cegr20 cegr20 is offline
Default 68 Chevelle Coil Springs
I have a 68 Chevelle with sagging rear coil springs and want to change them. Any recommendations on what to replace them with? I would like to replace the front and the rear. I thought of getting heavy duty springs to give it a slight lift? I know this would give me a rougher ride! There seems to be alot of spring choices out there any ideas?
Old 06-25-2012, 03:40 PM
Here is the Moog part number for front oem options, with spring rates, loads and install heights.
Old 06-29-2012, 05:18 PM
Thanks for the information on the springs I appreciate it!
Old 06-29-2012, 08:56 PM
Great graph Bull.
Old 06-30-2012, 07:12 AM
your welcome and thanks.
i really wanted to go with that 8602 spring. but the total diameter scared me as it is a lil less wide. free height was low and wasn't sure how that would go either.
400/424lbs is where i wanted to be, with stock being at 318 and all these after market performance springs being 500+ something right in the middle was my thought.
i decided to go with the 5380 and see what a new spring gets me. i can always cut it a little later to get a 1/2" to 1" drop which will also give me an increased spring rate.
got some QA1 adjustable shocks for all corners as well. bit more then i wanted to spend but i have a disease calls chevelleitis
