Old 08-06-2012, 07:57 AM
John's Avatar
John John is offline
Default Rear differential leak
Got a question. I've had my car about a week. I've been watching all the typical areas for leaks (front and rear main bearing leaks, trans and differential). I took the car for a short spin Saturday and on Sunday, noticed a small pool of oil under the rear differential (size of a pancake). Prior to Sunday, I was not getting any leaking from this area.
Will those seals just fail?
What is level of difficulty to replace?
Old 08-06-2012, 09:47 AM
i used these two videos to help me learn
http://www.youtube.com/watch?v=HNkGdByzyjI
http://www.youtube.com/watch?v=15zHpz6Zx8c
Old 08-06-2012, 10:49 AM
John's Avatar
Shaun-thanks. I'll take a look at those videos
Old 08-06-2012, 05:58 PM
Is it leaking from the front, pinion seal, or the rear cover seal? Hard to over fill the rear but you might want to check the fluid level.
Old 08-07-2012, 07:27 AM
John's Avatar
Yes-the pinion seal. I've never had a car where I've had a substantial leak at the pinion seal. Just a very strange encounter to see that pool.
Old 08-07-2012, 10:10 AM
if you do it the way the video shows with a little bit of gray rtv you will be fine for a long time!
Old 08-08-2012, 08:18 AM
John's Avatar
Shaun, the video was great. thanks again. question, when you did your repair, did you do it on the ground? The video makes it look easy with the car on a lift!
Old 08-08-2012, 11:27 AM
lol yes i did it on the ground it wasnt as easy but it was pretty easy for me because i had the seal puller
Old 08-08-2012, 03:26 PM
John's Avatar
Ok. Good to know you had no issues. would you recommend having a seal puller on hand? I thought they pried out pretty easy?
Old 08-09-2012, 07:52 AM
lol no mine did not come out easy at all! unless you have a trick to do it i would have it
