Old 05-24-2013, 10:07 AM
jacokyla11 jacokyla11 is offline
Default uneven rear
The driver side rear of my 71 chevelle is 1 3/4" lower than the pass side. I have changed rear springs and have the same problem. Any ideas if I have a frame problem?
Old 05-24-2013, 04:49 PM
Frame height is pretty much determined by the suspension, axle, tires, springs. If you've changed springs I can't see the frame being off that much although anything is possible. Have you measured from frame to ground while sitting on a level surface? Is the frame off that much or is it the body that is off? Have you measured body, floor pan, trunk pan, distance to the frame? Have the body bushings been changed?
Lots of questions, I know, just some things to think about.
Old 05-25-2013, 06:58 AM
Default uneven
Thanks for the feed back, I have not measured trunk pan or frame I will do that . I will check body mounts that may be it thanks for the feedback
Old 05-25-2013, 08:11 PM
Never thought about those things Hank. I am going to check mine. Thanks..
