Old 07-16-2013, 10:43 PM
Rattler's Avatar
Rattler Rattler is offline
Default QA1 Coil overs
Hey gang, I just purchased a set of the QA1 Pro adjustable front coil overs with the 350lb springs. I was wondering if anyone is using this setup and are you happy with your ride and could you get the ride height as low as you wanted to with these. Thanks!
Here is the setup.
Old 07-25-2013, 05:39 PM
Rattler's Avatar
Some of you are using QA1's aren't you? what spring weight did you go with and are you small block or big block?
Old 06-08-2016, 10:05 AM
70SS454's Avatar
70SS454 70SS454 is offline
I am looking at the complete stage two coil over set up from QA1. They supposedly are a good product and bought their product line from edlebroc. Did you end up putting the QA1 on the front of your car? How do you like it?
Old 05-15-2018, 02:55 AM
dconnor dconnor is offline
QA1 rides and handles great. Viking coilovers are good also.
