Old 09-13-2013, 02:13 PM
Roy '65's Avatar
Roy '65 Roy '65 is offline
Default Wiper motor
Well, finally got the A/C installed yesterday and today started to get the wipers wired. No problem as the hot wire from the switch went to the top terminal on the motor and the bottom terminal went to ground. Motor runs fine ...........in one direction only so when hooked up to the wipers only will run one way and not come back. My question is this a defective motor, wrong motor or do I have it hooked up wrong? The motor came with the car when I bought it and was supposed to be new and never hooked up until today.
Old 09-13-2013, 05:22 PM
I'm not sure but I think the motor only runs in one direction. The reverse sweep is accomplished with the levers, like a crankshaft and piston rod.
Old 09-15-2013, 01:57 PM
Roy '65's Avatar
Hank, then I have wiper trans. problems as when run by hand you need to bring it back vs having it go around to reverse.
Old 09-21-2013, 06:08 PM
crankshaft crankshaft is offline
same with mine. I just finished wiring my 65 chevelle. The park position needs to be done by hand .
