Old 10-21-2013, 06:34 AM
71-SS350 71-SS350 is offline
Question Body Bushings-Poly or Rubber ?
Looking for advice on replacing the 40+ year old body bushings on my '71 Chevelle. Not headed for a 1,000 point show restoration, just will be a nice, clean driver. Wanting a good, smooth ride feeling for wife and I when we take it out. So, should I go with rubber or poly bushings? Who has the best quality and best price, quality over price first consideration. Thanks.
Old 10-21-2013, 06:56 AM
I guess for ride quality you would want to go with rubber. Poly is much harder, doesn't compress as easily. I bought a set from NPD about 9 years ago. It came with all the hardware, bolts and washers. Everything was in numbered bags with a diagram to show which bushing and bolt to use where. I've heard a lot of complaints from others that the kits they bought had no instructions and couldn't figure out what went where. I would talk to the people at NPD to make sure the current kit is the same as the one I bought.
Old 10-21-2013, 08:46 AM
so far all of the ones i have replaced are solid rubber ones. only have about 25 miles on it but feels good so far
Old 10-21-2013, 09:27 AM
I would go with rubber, everything poly I have ever had tends to dry rot, and become very brittle. My 72' still has original body bushings, and they look amazing. However, I do have a 49K original mile car.
Old 10-21-2013, 09:40 AM
I used the urethane bushings from OPG.
I changed them out in 2007...and have no problems.
As for bolts...i used grade 8 from the hardware store.
Old 10-21-2013, 11:32 AM
Stormer's Avatar
Stormer Stormer is offline
Rubber bushings from NPD here too.
One and a half year and only 1.500 miles of use, but so far so good.
I recomend.
Old 10-21-2013, 07:48 PM
Rubber all the way for body bushing. Poly bushing will let any vibration you have come through the body. I have poly bushings in the front end of my car and rubber in the rear.
Old 10-21-2013, 08:24 PM
Thanks for the replies. Looks like the rubber bushings get the nod. Any idea where to go for best quality and cost on a bushings kit? Also, since almost 65 years young with the bad back to prove it am considering having it done at a body shop with the proper tools and guys younger than me to do it, LOL. How long does such a job take and a fair cost for such?
Old 10-21-2013, 08:37 PM
Most vendors all sell the same bushings. If you are going to replace your body bushing be sure to spray the bolts with something like PB blaster penetrating oil so you dont spin a cage nut in the body. Also it's a good time to replace the old gas line since you have the body lifted. Vendors NPD, Ground up, Yearone, Ausley are some good options. I alway like to buy local, thay way I can look at the parts I'm getttting and if you build a relationship with them, then you won't have a hassle returning something.
Old 10-24-2013, 08:14 AM
Any tips on replacing the body bushings besides using the PB Rust Blaster on the caged nuts? How many body bolt/bushing combinations are there on a '71 2 door coupe? Am I better off lookinf for a body shop or mechanic shop to do the job or is it something I can do in my shop? Have a concrete floor and floor jacks and stands but have never done this before. I did take the Chevelle to a reputed good body shop and to replace the body bushings, (I supply them) and repair the rear trunk floor with a 3 piece set (I supply) I was quoted a cost of $2,785. WOW, talk about sticker shock !! Can that be a fair price? They said minimum of 45 hours for the bolts and trunk floor.
