Old 02-26-2014, 01:35 PM
jcoffey411 jcoffey411 is offline
Default Need cam suggestions
71 chevelle 3400 lbs guessing
355
9.5:1 compression
AFR 195cc street heads 2.05/1.90
Performer RPM air gap
650 or 750 cfm carb have both
700r4 2600 stall
2.73 but 3.73 or 3.90 going in the spring
26" tire
Can not afford a roller so solid flat tappet it will be
Lunati recommended
30120741 Voodoo series
2600-6800
276/282
241/249
.520/.540
110/106
Comp has 4/7 swap
12-664-47
2400-6800
282 / 290
244 / 252
.520/.540
110 / 106
I ran the comp non 4/7 swap same spec in desktop dyno 2003 did not do as well as Lunati's grinds
Open to suggestions will be ran on the street or I would have ran Lunati's oval tight lash 2
30121102 which kicked the most in dyno simulation but for the street not so much
2500-6500
272/280
243/251
.530/.543051
106/102
Open to opinions and suggestions
Sent from my SPH-L720 using Tapatalk
Old 02-26-2014, 05:13 PM
What is the primary use of the car? 241/249 @ .050" seems HUGE for a street driven 355 with a 2600 converter.
IMHO - I would like to see a cam with less overlap to build compression, rather than bleed it off. The lunati cam has 25 degrees of overlap. I bet the DCR sucks with thats camshaft.
I would like to see something like a 230/234, on a 112 LSA, 108 or 109 ICL, and .550"-ish lift. I know a SFT cam loses some of the specs through the lash, but I think the modern grinds require less lash... therefore not as much of a loss.
Focus on power under the curve instead of peak power. Just my $0.10 worth...
Old 02-26-2014, 05:45 PM
And forget the 4/7 swap...waste of time, money and effort on a mild street engine.
Old 02-26-2014, 06:50 PM
Road course protouring auto-x and drive during the summer.
Old 02-26-2014, 06:56 PM
I have been playing with close to 12 different cams in the desktop dyno program and 106/102 gave the best numbers without falling on its face after 4500 the other cam that looked good is a 108/102 oval track cam also grind 30121101 which is 2000-6500
268/276
239/247
.521/.540
108/102
Old 01-08-2015, 09:58 PM
update ended up with an isky 246/246 @.050 274/274 advertised .534/.534 lift on a 108 love it works great with my setup. I did have to put in a vacuum canister to help with the breaks though.
Sent from my SPH-L720T using Tapatalk
Old 01-09-2015, 05:16 PM
Good choice on the solid flat tappet....will out perform a hyd roller every time.
Are your power brakes ok ...perhaps a hydroboost setup.
Btw a larger lca will give more vac and have a wider power band but gives up some peak
power and torque.
Old 01-09-2015, 08:04 PM
Single pattern and tight LSA should be very torquey. What's the ICL?
Old 01-09-2015, 09:54 PM
True ICL 108 I will try to post some pics tonight of the cam change. I ended up paying more for lifter than the cam but here was the parts list for the cam change. Realize this was done in the summer and I found three wiped lobes on the old camshaft. More pics will post what I got.
Ati-917781 harmonic balancer
Cloyes 9-3100 timing chain
Fel-Pro 1205 intake gasket
Fel-Pro tcs45165 timing cover set
Lucas 30 break-in oil 5qt
Piston stop
Summit degree wheel
Isky SO202H lifters
Lunati 30121101 cam
Aem 30-4110 wide band gauge
moroso 73800 ultra 40 wire set
And some ebay protector boots
coolant from the local parts store.
Old 01-09-2015, 10:09 PM
I also wanted to add I did my homework before buying the cam used Vizard's formula to spec it out
