Old 06-28-2016, 10:09 PM
Chris69Chevell's Avatar
Default Vented Gas cap?
Hey guys I just installed a new gas tank from right stuff detailing CFT6801 on my 69 Chevelle.
I am having trouble finding a vented gas cap that will work, I think I need the deep style. The only deep style vented cap that I can find is for a 70 chevelle.
What would be the difference between the 69 and 70?
Thanks!
Old 06-29-2016, 04:04 PM
Maybe only in design, should work fine.
Old 06-29-2016, 11:06 PM
I called right stuff detailing today were the tank came from and they were zero help. I went ahead and ordered the deep style cap for the 70, I hope it works.
Thanks.
Old 10-21-2018, 10:36 AM
ghackett1 ghackett1 is offline
I'm having the same problem with my 68 Elky SS. I paid more for the better tank, not vented as per the original tank I removed (Gas Cap Missing) and I can't find the right vented cap. I bought 2 so far, First one too shallow, second one too deep. Seems like there should be a middle one but I just haven't had luck yet so at least the deep one keeps dirt out.
Old 10-21-2018, 04:39 PM
Geez I just realized this post is 1 1/2 years old? Where the heck is everybody?
Old 10-21-2018, 07:12 PM
What I ended up doing is going with a regular non vented cap and added this vent to the tank. Your tank should have two nipples top right.
https://www.ebay.com/itm/69-70-71-Ch...2:pf:0&vxp=mtr
Old 10-10-2019, 03:39 AM
dconnor dconnor is offline
I got a reproduction one on oerparts and it fits fine.
Old 10-12-2019, 09:00 AM
pitts64 pitts64 is offline
Lutty has NOS caps...
Old 10-12-2019, 11:21 AM
I just shove a rag in the hole with some duct tape.
Old 10-16-2019, 03:44 PM
You need the tank with the three vents across the top. Plug the two end ones and run a gas filter to the center. Mount the filter up high, this will be the new vent. This cured all my gas issues on my 69 el Camino, especially the gasoline smell...
I am on my third tank in three years, they all leak. I am just getting this one coated at the radiator shop. If you have a new one might as well get it coated before installing it..
So there it is,
Buy the cheap tank with three vents across the top and have it coated before installing...
