Old 01-25-2017, 06:52 PM
Chrisw Chrisw is offline
Default Replacing headliner with the windshiled and windows still in..?
The car needs a new headliner and every write up I see is the same. Use the clips and the glue. Sounds great, except that I cant fit the clips in at the front and rear because I have my windshield and rear window still in.
Is there a simple work around for this? I assume there is.
Car is a '69 A body coupe.
Thanks in advance!
Old 01-26-2017, 07:47 AM
? I replaced mine, 70 Chevelle, with windows in. I used a lot of the small black spring clips. Didn't really have a problem getting the clips on that I recall, it's been a few years. Maybe the clips you have are just too big.
Old 01-27-2017, 08:47 AM
Small clips should work and your tack strip should also help hold it.
Old 01-29-2017, 02:01 PM
Ok, I guess I will try to find some smaller clips. I will see how it goes. Thanks!
