Old 05-22-2017, 11:47 AM
jcaro10894 jcaro10894 is offline
Default 1969 Dash Removal
Is removing the dash on a 1969 Chevelle Malibu difficult and do you need any special tools. I can see that my dash is missing one of the bolts that hold it to the body and can see a gap. I want to remove the dash pad so I can see what happened to the screw holding the dash.
Old 05-22-2017, 05:57 PM
Not sure as mine is a 70. It has screws that go up in the front of the dash and hold the dash pad down. Once those screws are removed you can lift the dash pad up and slide it out. It has springs clips that hold the other side, at the windshield, down. They slide into the metal framework inside the windshield. Don't remember but the A pillar covers may have to be removed as well to slide the pad out. Once the dash pad is removed you can see what holds the dash itself on.
Disclaimer: Not sure if any of the above will apply to a 69.
Old 05-22-2017, 11:28 PM
Thanks for the information.
Old 05-23-2017, 05:28 AM
It is the same as my 68. Steering column has to drop down. Remove all the screws you see around the edge. Couple metal braces in the back screwed to the back of the instrument cluster. No special tools mainly a Phillips screwdriver and tiny socket set. Once it drops down you can access the wiring from top and bottom.
Old 05-28-2017, 09:35 AM
pitts64 pitts64 is offline
Removing the dash pad will not reveal much, it's all steel under there.. I had my 69 El Camino all apart 2 years ago..
Were is the gap? Mine always had a weird gap on the far left...
Name:	floor dash 1.jpg
ID:	4165   Click image for larger version
Name:	interior wiring.jpg
ID:	4166   Click image for larger version
Name:	Dash drivers side new.jpg
Old 05-28-2017, 11:13 PM
Default pitts64
Thanks for posting the pictures. I may not have to remove the dash pad to see why the screw that holds the instrument cluster is missing. The cluster has moved away from the stamped metal leaving a gap.
