Old 11-29-2018, 07:02 PM
69-chevy1 69-chevy1 is offline
Default SS gauge connections to LS2
Hi all, I am in the final stages of swapping an LS2 into my 1969 Chevelle SS. My current problem is connecting the SS instrument gauges (battery, temp, oil press) to the LS2 so I have some idea what is going on inside the engine. Can anyone out there give me some advice on how to do this? I suspect that I'll need new sensors for the LS2 that are appropriate (electrical resistance?) for the original SS gauges.
Old 12-02-2018, 04:33 PM
Should have some ports in the heads to screw a temp sensor into. I would use original sensors, if they fit the threaded port. Battery, on a 70 that's at the horn relay. Which is the main connection point between the alt, battery and fuse block. Really just about any 12v connect will work, maybe the fuse block.
Old 12-02-2018, 07:07 PM
They sell threaded adapters for installing older style sending units or oil press lines into LS engines.
Tags
ls2, ss gauges
