Old 04-16-2019, 11:26 AM
kevinw kevinw is offline
Default rear air shocks not holding air
hello.
I have 69 Malibu
it came with air shocks from previous owner, has two lines that go to inside trunk. however, one line from one shock has leak, wont hold air
is there a way to repair or just replace the lines without buying all new shocks?
thanks
Old 04-16-2019, 02:58 PM
If you're sure it's just one of the air lines leaking then just replace it. Shouldn't be to hard to find replacement hose.
Old 04-16-2019, 06:35 PM
Replacement air line kits are available...check Jegs or Summit
Old 04-17-2019, 08:05 AM
ok thanks, appreciate it
Old 04-17-2019, 08:28 PM
I would put Coilovers on and get rid of the Air Shocks .
Old 05-15-2019, 10:28 PM
dconnor dconnor is offline
+1 on coilovers. They can improve the ride quality of your car.
Old 09-29-2019, 05:06 PM
pitts64 pitts64 is offline
When I swapped the air shocks out for new Bilstine shocks, I was amazed at the difference. I agree with the others who say to remove the air shocks.. I didn't do coil overs since I have SPC upper and lower control arms that come with spacers..
