Old 04-05-2010, 10:40 AM
mill540 mill540 is offline
Default 72 Trunk Lid Emblem
Does anybody have the hole placement measurements for the 72 Chevelle by Chevrolet trunk lid emblem?
Also, what holds the emblem on? Some sort of adhesive? Some kind of clip?
Thanks in advance for your help.
Old 04-05-2010, 10:52 AM
grumpy's Avatar
grumpy grumpy is offline
Administrator Bowtie Member
Pretty sure the emblem is held on with barrell nuts. Not sure of the placement as our car is in the shop.
Dave
Old 04-05-2010, 10:57 AM
The 70 emblem has a couple of barrel nuts and a couple of pins with a spring type clip on it. The 70 emblem is different so I suspect the holes are in a different location as well.
Old 04-05-2010, 11:05 AM
Happen to have any pics or links to pics of the nut or the clip? I bought the part from the parts place, the pins on the back don't seem to have any threads?
Old 04-05-2010, 11:26 AM
I might have an extra emblem with the clips on it, have to dig it out. The nuts are emblem nuts, just a a thing piece of steel stamped into the shape of a nut, hollow on one side. No threads on the pins, the nut will cut it's own thread.
Old 04-05-2010, 12:44 PM
I did a search on the web for "emblem nuts" and didn't have much luck. Do you know where I would look to find these?
Old 04-05-2010, 01:32 PM
Found them on ebay....hope to find a different version local at Lowes. I was also given the hole measurements.....thanks for the help.
Old 06-08-2010, 07:52 PM
68 nova 10.5's Avatar
68 nova 10.5 68 nova 10.5 is offline
Send a message via Yahoo to 68 nova 10.5
they are called barrel clips 1/8" Where are you located?
Old 09-10-2010, 10:10 PM
chevybuff chevybuff is offline
Thumbs up
I installed the trunk emblem as directed by the assembly manual and messed it all up! Those vague drawings in the manual couldn’t have been more wrong- it advised 00.55 inches from the right side of the trunk deck so I drilled the holes and when I went to install my badge, the mounting pegs were hitting the back side of the trunk.
It comes out to 1.25 – 1.26” now and I think the holes are 3/16" in diameter. Make sure you lay them all out and compare them to your emblem before drilling any holes.
Not sure this reference will help guide you to finding your style, but see wassup buddy and let me know if you need further help – http://www.restorationperformance.co.../28/Categories
http://www.classicdiscountparts.com/servlet/Categories
Good luck to you!!
