Old 06-10-2010, 05:56 PM
Default Wanted correct 1970 washer pump
I need a washer pump for my 70 that is correct. I know that they were not just exclusive to the chevelle, that most GM car used the same pump. The after market ones are not even close. Just another part to complete this car.
Old 06-12-2010, 11:41 PM
zombie1969's Avatar
I knew I had one.So I tor my shed apart.Turns out its the one that fits mine.Didnt relize I had one.That still might be something you can find in a salvage yard.Salvage yard rule is if it fits in your pocket its free.
Old 06-21-2010, 11:53 PM
Found one at the swap meet this last weekend for $5, and got some extra parts for a $1. I lucked out. Again it was buried in a box in the corner under the table, so if you go to swap meets look in the boxes under the table. I have found more treasures under the table then I have found on top.
