Ric, what I need to know is how far the spool travels when the brakes are applied. Can you get Les to push down on the brake pedal at the same time that you put your finger between the metering valve and the MC, where the rubber boot covers the stem end of the spool? You will feel the spool move. Mine on the Nova is only moving about 1/8th of an inch. I don't know if that is far enough. I'm trouble-shooting a problem on it.
