Old 02-08-2022, 12:22 PM
Scott68convert Scott68convert is offline
Default 68 Malibu Convertible- under dash part
Hello,
New to the group. Can anyone tell me what this part is? It fell out from under my dash as I was working on replacing bulbs in the panel. Also, the column shift indicator does not move off of park. are they related??
Old 02-09-2022, 06:27 AM
It is a shim. there are 2 metal post coming down from the upper dash. The brake/clutch assembly and steering column meet. Look there you will see more. It gores between those parts on the rod.
It didn't fall out. It was lost when whoever assembled it. And it finally fell out.
Old 02-10-2022, 09:39 AM
AH, thank you. I did lower the steering column to get to the back of the dash panel. should I try to wedge it back in? what is it suppose to line up with?
Old 02-10-2022, 06:01 PM
Just look at the other side. the 2 parts are at 2 different angles. Hence the wedge shape.
Old 02-11-2022, 10:29 AM
Found it, thank you
Old 02-12-2022, 05:37 AM
Welcome pics please.
