Old 10-20-2010, 12:31 PM
Zoomy Zoomy is offline
Default CS130 Alternator Conversion
Hey;
I'm new to this forum.
I "Repurchased" my old '72 Chevelle just recently.
It was "suppose" to have been "almost" restored & in great running condition.
NOT !!!
The alternator died within the week.
I have a CS-130 Alt. I'd like to retro-fit.
** My only problem is the Upper Bracket.
I'd like to keep it on the original/shotgun side.
The upper alt mounting hole is at the 10/11 o'clock position
as opposed to the OEM 12/6 position.
I know someone has done this before.
Any Help would be appreciated.
Thnx
Old 10-20-2010, 02:23 PM
You're saying the mounting holes are at 10/11 or the upper hole is somewhere around 10 or 11? Some CS130s have 12/6, some have 2/6. There may be other configurations.
If your upper hole is at 10, looking from the other side would be 2. That will work on a driver's side mount but not on the passenger side unless you fab up a new upper bracket. Worst case you buy a new one with 12/6 mounts and use yours as a core.
Old 10-21-2010, 01:44 PM
Yes
The Upper mounting hole is at 10 or 2 depending on how you look at it.
And
Figured out my mounting problem.
I saw a picture of Marsh Alternator Brackets on Summit.
It uses a Turnbuckle & an offset bracket That I made.
Went to True Value and came up with my own.
Will be putting it all together this weekend.
Later
Old 10-21-2010, 05:58 PM
Great, glad you got it sorted out.
Old 10-21-2010, 07:47 PM
By the way Zoomy, welcome to the site.
