Old 06-01-2011, 10:02 AM
Default carb size
ok so now that i know what distributor i am going to order now i need to know what carb i should run. I am running a 454 in my chevelle its mostly stock. here is the cam spec
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 1,700-5,200
Intake Duration at 050 inch Lift 218
Exhaust Duration at 050 inch Lift 228
Duration at 050 inch Lift 218 int./228 exh.
Advertised Intake Duration 276
Advertised Exhaust Duration 286
Advertised Duration 276 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.500 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.500 in.
Valve Lift with Factory Rocker Arm Ratio 0.500 int./0.500 exh.
Lobe Separation (degrees) 114
rockers are a 1.7
the motor is stock compression not sure which motor it is as far as what 454 but my pistons look like this
(not my pistons just found a random pic on the net but those look exactly like my pistons) i was told i needed an 850 with mechanical secondaries i think that is a bit much for a car that is pretty much never going to see about 4000 rpms and never see a drag strip with this motor and trans setup. so what do you guys think? 670 vacuum secondaries? 750 vacuum secondaries? help me figure this out
Old 06-01-2011, 01:41 PM
ok so someone just taught me what i need to look for to come up with my calulation of what carb i need and turns out i need a 670 thanks guys!
Old 06-01-2011, 02:36 PM
I'd be looking at a quadrajet if I was you. They are the best of both worlds, economy for cruising, and secondaries the size of texas for when you romp on it.
Old 06-01-2011, 06:31 PM
An old Quadrajet is good option if you can find a decent one. Only problem is the spread bore, if you have an intake with spread bore great. If square bore than Edlebrock or Holly make good crabs. I'd be looking at the 750 cfm range for a 454, vacuum secondaries based on how you plan to use it. You will spin it past 4000 rpm, at least 4500. If you don't then you should have put in a 4 cylinder. Seriously, it's hard not to spin past 4000.
Old 06-02-2011, 10:28 AM
lol i redid my calculations and it cam out to be more towards i need a 750 i was looking at this one
http://www.summitracing.com/parts/HLY-65-3310S/
i have a 2 4 cylinder(one car one motorcycle), 6 cylinder (my magnum for everyday use)an ls6 (my rx7) and now my 454 so i think i have the best of all worlds and my chevelle will not have a 4 cylinder
