Old 01-31-2012, 06:07 PM
70SS396 70SS396 is offline
Default removing the master cylinder and booster
How hard/easy is it to remove the master cylinder and booster from a 1970 Chevelle? Mine is painted all black and I want to strip the paint off to reveal the brass color of the booster and paint the master cylinder silver.
Thanks,
Mike
Mike
Old 01-31-2012, 07:32 PM
Its so simple even I can do it and thats simple .Just unbolt and re install the reverse of how you took it off. Just dont lose the rod on the back of the booster .Be careful not to strip the nuts on the lines ,dont use a regular wrench.Go to your auto parts store for a pair of line wrenches ,dont remember the sizes but my 72 had one smaller than the other .
Old 01-31-2012, 07:33 PM
Hey,if I did it anyone can. 4 bolts on the firewall and it's off once you remove the rod from the brake pedal.
Old 01-31-2012, 07:35 PM
Hey Flash,you beat me. I think I am simplier than you.
Old 01-31-2012, 08:07 PM
Thanks guys. so there are just the 4 bolt and a rod connected to the brake pedal? And the 2 brake lines of course. sounds easy enough. Thanks!
Mike
Old 01-31-2012, 09:49 PM
Thanks,
Mike
You may have to have the booster replated if it's been painted and the master cylinder should be painted cast gray
Old 02-01-2012, 06:46 AM
If that's the case, I might as well buy a nice shiney chrome one.
Mike
Old 02-12-2012, 01:52 PM
Bowtie-Bri's Avatar
Here's a couple sites to consider if you want to restore your booster and master.
http://www.brakeboosters.com/ Steve Gregori is great to do business with.
http://www.resleeve.com/index.htm This place can rebuild your master. They will also powder coat it in the cast gray.
Name:	LS-6 showboard pics 039_resize.jpg
Brian
